Testing and results
We followed our standard case testing methodology, as detailed in our
previous heatsink and case testing article, and fitted the usual set of hardware into the case, doing our best to hide and tidy cables to ensure as few airflow restrictions as possible. Luckily this wasn't difficult in the GS1000 Plus. Here's a reminder of the hardware we use.
- CPU: Lapped Intel Pentium XE 955 (dual-core, 3.46GHz)
- Graphics Card: Sapphire Radeon HD 3850 Ultimate passive cooled
- Motherboard: MSI P6N SLI Platinum
- RAM: 2 x 512MB Corsair XMS2-667
- Hard Drive: 1 x 250GB Western Digital WD2500 7,200RPM
- Heatsink: Asus Silent Square Pro
- Power Supply: Xilence XP700 700W PSU
While this isn't representative of current high-end hardware, the equipment we use is specifically selected to kick out the maximum amount of heat inside the case. With a passively cooled graphics card and 130W TDP processor at its core to really heat things up and push the case's ability to cope with toasty components to the limit.
In our experience, our CPU stress test is a good way of indicating a case's ability to exhaust hot air and the GPU stress test is a better indicator of a case's intake ability. This is because the GPU is generally further from the exhaust fan and so its operating temperatures rely more on case airflow than exhaust.
Following feedback from the
bit-tech community, we've changed the way we display case thermal performance. We've removed ambient and case temperatures from our graphs and just left the more important values of GPU and CPU Delta T – the differences between the ambient temperatures and the component's temperature. We feel this provides a much clearer representation of a case's cooling ability where it counts, as well as producing results that are much easier to digest.
      Lian Li PC-P50
      Cooler Master HAF 922
      SilverStone FT01
      Gigabyte Sumo 4112
      Zalman GS1000 Plus (Full Speed)
      Antec Nine Hundred Two (Minimum Speed)
      Antec Nine Hundred Two (Full Speed)
      Zalman GS1000
      Akasa Omega
      Cooler Master ATCS 840
      Lancool K7 Metal Boned
      Zalman GS1000 Plus (Minimum Speed)
°C
      SilverStone FT01
      Gigabyte Sumo 4112
      Zalman GS1000
      Lian Li PC-P50
      Akasa Omega
      Antec Nine Hundred Two (Low Speed)
°C
      Lian Li PC-P50
      Zalman GS1000
      Akasa Omega
      SilverStone FT01
      Gigabyte Sumo 4112
°C
